Wateroverlast door slecht onderhoud dak en regenpijp
13
Isabella
Isabella
#Budget · 6 jaren geleden
Buurvrouw laat haar huis verkrotten waardoor er geen regenpijp meer hangt en bijna geen roofing op zit...de kinderen hebben de blote eigendom ..
kunnen de kinderen verantwoordelijk gesteld worden..kan ik afdwingen om het te maken en hoe ?
https://livios-images.imgix.net/livios/forum/messages/57599/c4958ea6-0506-438d-9776-f57ab85b4f74.jpeg?auto=format&fit=crop&crop=faces%2Cfocalpoint&q=85&corner-radius=10&mask=corners&s=49d76a31beaab396a4bb933331f27bf4https://livios-images.imgix.net/livios/forum/messages/57599/f2668037-438f-49cc-93bd-93407f66da42.jpeg?auto=format&fit=crop&crop=faces%2Cfocalpoint&q=85&corner-radius=10&mask=corners&s=003f0430fafb3b7866bf86eb71f6d841https://livios-images.imgix.net/livios/forum/messages/57599/e5a24708-1160-4f72-a9a6-04f7dd0082d4.jpeg?auto=format&fit=crop&crop=faces%2Cfocalpoint&q=85&corner-radius=10&mask=corners&s=13e84410b7ae350a62a9ddf289a7b24fhttps://livios-images.imgix.net/livios/forum/messages/57599/06dc2e9c-0104-49c3-8660-41e38c41da56.jpeg?auto=format&fit=crop&crop=faces%2Cfocalpoint&q=85&corner-radius=10&mask=corners&s=10512dd15bd8887bf6af7025551e7304https://livios-images.imgix.net/livios/forum/messages/57599/3e82cb20-edc1-442d-b2c8-7939b49ebafe.jpeg?auto=format&fit=crop&crop=faces%2Cfocalpoint&q=85&corner-radius=10&mask=corners&s=5e3927e22c0d31448222b8a8da6c61e5https://livios-images.imgix.net/livios/forum/messages/57599/315b4c84-72b4-4424-8fe4-cc3d06b2ffa3.jpeg?auto=format&fit=crop&crop=faces%2Cfocalpoint&q=85&corner-radius=10&mask=corners&s=b6b63eb82f1699aa09dfdbebfd32f91dhttps://livios-images.imgix.net/livios/forum/messages/57599/4b0022b0-a391-408c-bfda-4f3c21d5ed0f.jpeg?auto=format&fit=crop&crop=faces%2Cfocalpoint&q=85&corner-radius=10&mask=corners&s=b933601d0672fac7cd8e19a33e651bb8https://livios-images.imgix.net/livios/forum/messages/57599/adcf5b6c-fab3-4afd-8575-45814eb8a29f.jpeg?auto=format&fit=crop&crop=faces%2Cfocalpoint&q=85&corner-radius=10&mask=corners&s=470b18b5ad2bfcb71547e4435e34626dhttps://livios-images.imgix.net/livios/forum/messages/57599/95bbb10a-d573-46a3-866c-0c792d79e667.jpeg?auto=format&fit=crop&crop=faces%2Cfocalpoint&q=85&corner-radius=10&mask=corners&s=8726ca0d123a585c4bbb57433ca24fa2https://livios-images.imgix.net/livios/forum/messages/57599/a112aa3b-bb2c-4469-b1f3-306a25261835.jpeg?auto=format&fit=crop&crop=faces%2Cfocalpoint&q=85&corner-radius=10&mask=corners&s=856eddb0c1c5c0d46e5217907db22811
Patrico
Patrico
135 1470 Andere professioneel
Heb je je buur eigenlijk al aangesproken hierover? Dit soort schadegevallen worden gedekt door je woningverzekering/familiale. Neem even contact op met je verzekeraar en leg hem het geval uit. Hij zal je kunnen vertellen wat je moet doen.
Isabella
Isabella
0 8 Andere particulier
Gaat niet via de verzekering,ze heeft geen brand en familiale...ik wel maar het is ik niet dat schade berokken
Ik zie aan de woning links een regenpijp, aan de woning rechts ook één.
Dus waar ontbreekt die regenpijp.
Nergens kan ik opmaken dat één van de 2 woning verkrot is. Ik zie wel een stelling met plankier hoger dan het dakraam rechts en daar -- slecht te zien op de foto's- een gebrekkige bozemplank, geen dakgoot als ik goed kan zien. Maar aan de andere kant , ze zijn daar werken aan het uitvoeren en precies aan de dakgoot zie ik nieuwe beugels
Waar bedoel je met er zit geen roofing meer?
Aan de linkse woning zie ik vocht schade maar ook dat de laatste rij pannen op de puntgevel precies is weggezakt. Bij het uitvergroten van foto 06dc2e9c-0104-49c3 -8660 zie je dat de bovenste gevelstenen breukschade vertoont. Ook valt het me op dat de dakgootzijkant niet tot einde muurvlak loopt en dat er precies met aluminiumfolie is gebricoleerd. Opvallend (laatstefoto) is dat de zeer poreuse snelbouwstenen tegen het muurvlak van de andere woning geen sporen draagt van vochtinsijpeling.
Afgaand op de foto's zou ik durven stellen dat de rechtse woning aan het renoveren is maar dat het niet vooruit gaat.
De linkse woning heeft een probleem met een verweerde schouw en een slecht aansluitend dak op de puntgevel
Isabella
Isabella
Die stelling staat er al 25 jaar en er is ook sindsdien niets meer aan gewerkt...oorspronkelijk ging de goot van de buurvrouw tegen het linkse huis maar die is er volledig af en er is nu een halve regenpijp tegen gebricoleerd.
als het regent komt al het water van het dak van het rechtse huis op de gevel van het linkse dak,het dak van het rechtse huis is heldaf naar links
Patrico
Patrico
Je komt naar hier voor advies, waar haal je het dat dit niet voor jouw verzekering is? Als dat van je verzekeringsagent komt neem je best een andere verzekering.
Isabella
Isabella
K zal ies horen bij iemand anders 🤔
omdat het geen plots gebeuren is en ik binnen huis nog geen schade heb ...en zij heeft geen brand en familiale polis en ik heb zo geen verzekering voor een advocaat..
932 5479 Andere professioneel
Beste, ik zie dat de buurwoning inderdaad redelijk verwaarloosd is. Echter op de foto's zie ik als enige schade aan uw woning dat die rechterhoek flink van insijpelend vocht te lijden heeft. Echter volgens  mij komt dat vocht niet van de buren maar is het uw eigen dak dat niet goed aansluit op de dakgoot.
Ik zou dat eerst eens goed laten nazien eer je de schuld op anderen gaat steken.
Want het is niet per definitie zo dat een verwaarloosde woning altijd schadelijk is voor de buurwoningen. In dit geval lijkt het er zelfs op dat uw eigen dak en dakgoot de oorzaak van schade zijn.
Isabella
Isabella
Ik begrijp wat je bedoelt maar door de hoeveelheid water is er ook een stuk weg bij mij ...k ben met een Dakwerker aant kijken voor een oplossing maar dat is niet makkelijk omdat je aan een ander zijn eigendom niet mag komen
Patrico
Patrico
Ik ging ervan uit dat je schade had, als er geen schade is kan de verzekering niet tussenkomen.Je had natuurlijk ook veel sneller kunnen reageren. Nu hangt het ervan af wat ze als schade omschrijven. 'Een stuk weg bij jouw' is toch ook schade?
Ik zou ook nog zeker kijken naar de opmerkingen hierboven betreft mogelijke eigen problemen.
Isabella
Isabella
We zijn er al mee bezig van 2017 ...een beetje beu omdat ze niets doet,kan haar voort gerecht laten komen maar dan nog is niets zeker...en dat geeft ook geen goed gevoel .
maar k ga zeker naar mijn dak laten kijken
